Activity Forums Maxon Cinema 4D How to model the curl of a flower?
  • How to model the curl of a flower?
    Posted by Alex King on September 4, 2013 at 4:53 pm
    Hello there. I am trying to model a petal of a flower but can’t find a solution to make the sides slightly curl ( almost like rolling a map ). The petal is made out of a hypernurb and simply looks like a basic petal. I have tried the bend and taper deformers with no such luck.
    Any suggestions? Thanks
    Brian Jones replied 13 years ago 2 Members · 3 Replies
  • Brian Jones
    September 4, 2013 at 5:27 pm
    animation of the curl or modelling the curl into the petal?
  • Alex King
    September 4, 2013 at 6:17 pm
    Thanks for the reply and sorry for not being clear. I would like to model the curl on the petal, which is an hypernurb shaped as a petal. Thanks
  • Brian Jones
    September 4, 2013 at 7:37 pm
    just modify the object that is in the HyperNurb to give you what you want. Can you post a simplified scene with just your petal?
