Activity Forums Maxon Cinema 4D How to Model a Head in Cinema Help Please
  • How to Model a Head in Cinema Help Please
    Posted by Romeo Meier on September 26, 2009 at 10:44 am
    I’m using this tutorial https://library.creativecow.net/articles/labelle_jannis/head_ee/Eyes.htm
    there is a Problem with it.
    1.) the Guy using this tutorial uses R7 and I’m using R11 which is so diffrent that this tutorial is not useful at all
    I have been able to find out everything up to that Part where i need to add the Points i have it in the right mode make a right click and choose add points but now when i click there are no points>>>> Why?
    2.) also he mentions that the Extrude Edge plugin supposed to be included in R8 thats why i assume that it would be included in every cinema newer than R8 BUT WHERE DO I FIND IT (its not explaind in which menu its supposed to be)
    Please answer me fast and in order to give me useful answers rathere explain to much as not enough i really need it explained in baby steps very precisly.
    Romeo
    Alan Lacey replied 16 years, 11 months ago 3 Members · 10 Replies
  • 10 Replies
  • Adam Trachtenberg
    September 26, 2009 at 9:15 pm
    1) Hold down the control key when you click;
    2) Use the extrude command (works with polys and edges).
  • Romeo Meier
    September 27, 2009 at 10:34 am
    Ho do I do that with “Extrude Command” how do i find it?
  • Adam Trachtenberg
    September 27, 2009 at 5:48 pm
    [Romeo Meier] “Ho do I do that with “Extrude Command” how do i find it?”
    Structure>Extrude, or
    Right-click menu>Extrude, or
    shortcut key “T” (hit M key to see all modeling shortcuts).
    Also explained in the html help system (Help>Help).
  • Romeo Meier
    September 28, 2009 at 12:09 pm
    Thanks so far but how do I make round edges (creating a face) with “Right-click menu>Extrude” Function?
  • Adam Trachtenberg
    September 28, 2009 at 2:03 pm
    I’m not sure what you mean by “creating round edges”. Can you provide a link to the tutorial step you’re stuck on?
  • Romeo Meier
    September 28, 2009 at 6:00 pm
    it’s the same link, picture 6,7 and 14 i want it to look like that but when i do that it’s very flat and it has to many corners but in these pictures everything is round and the eyes are bent a little.
  • Adam Trachtenberg
    September 28, 2009 at 6:48 pm
    Looks like you skipped the part where he puts the geometry in a Hypernurbs object. Check the second image on that page.
  • Romeo Meier
    September 28, 2009 at 8:11 pm
    no i did the hyper nurbs but the eyes had corners on each point i did and on the picture it didn’t have corners at all that is why i originally asked where i can find the edge extrude plugin since it is supposed to be integrated in R8 which makes me believe that it also will be integrated in R11 I believe that extrude and edge Extrude is not the same.
    How would you model a head so that it has no unnecessary corners and would look like a real head?
  • Adam Trachtenberg
    September 29, 2009 at 12:46 am
    Extrude and edge extrude are the same thing. As I said, it’s explained in detail in the html help file.
    I can’t explain in a post how to model a head, I’m afraid.
  • Alan Lacey
    September 30, 2009 at 9:11 am
    You have my full marks in the ‘patience’ catagory Adam!
    Alan
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
