One method would be to convert that half to a smart object, and duplicate the smart object. Then flip horizontally, and rotate -90 degrees.
Any change you make in either one (by editing the smart object) is reflected in the other half.
Unfortunately, Photoshop’s smart objects cannot be edited in place (they open in a new window), nor do they update in realtime. So for this type of work it is rather inconvenient.
Photoline’s virtual layers are far more efficient: the original source layer can be edited in place, and changes do update all the clones in real-time.
You will have to live with Photoshop’s limitations in this case.
System: Win7 64bit – i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560×1440, HP 1920×1200 in portrait mode
