Activity Forums Apple Final Cut Pro Legacy how to merge cuts?
  • how to merge cuts?
    Posted by Juliett on February 24, 2006 at 5:30 pm
    Hello Again 🙂
    One of our editors is cutting a 2 hr long programme. (offline)
    He is working on many different parts at once which at some point will merge.
    He dragged the sequence into the timeline to merge the cuts and this created nested sequences which we don’t want for online purposes
    I suggested that he creates a main sequence then copy and paste the other sequence’s contents into the new one.
    Is this the way to do it or have I just given him the wrong advice.
    Thanks for any replies
    Julie
    Oliver Peters replied 20 years, 6 months ago 4 Members · 3 Replies
  • David Roth weiss
    February 24, 2006 at 5:59 pm
    Thats the way to do it.
  • Debe
    February 24, 2006 at 6:29 pm
    That’s the way to do it, Julie.
    debe
  • Oliver Peters
    February 24, 2006 at 8:12 pm
    You can also overwrite/insert “with sequence content” (defaulted to one of the modifier keys). This will avoid nested sequences. You can remap the keyboard so this is the normal condition, which won’t affect standard master clip edits. Doing this won’t retain links to rendered files from the original timeline (re-rendering required), though, whereas copy/paste will.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
