Activity › Forums › Adobe After Effects Expressions › How to match Rotation of Position Keyframes and Trapcode Stroke Offset
  • How to match Rotation of Position Keyframes and Trapcode Stroke Offset
    Posted by Ness Lange on March 11, 2021 at 3:04 am
    I’ve been creating a circular motion of an emitting light, that moves forward on every beat thanks to Soundkey integrating function (Rising values depending on beat):
    a = 150;
    f = 1/30;
    t = thisComp.layer("Keys").effect("Sound Keys")("Output 1");
    x = a*Math.sin(f*2*Math.PI*t)+thisComp.width/2;
    y = a*Math.cos(f*2*Math.PI*t)+thisComp.height/2;
    [x,y]
    I’ve linked this with the Trapcode particular, thus a nice particle trail emerges.
    I could have also used Dan Ebberts speed method. Maybe I have to because here comes the issue: I’ve applied Trapcode stroke to the circle and want the taper to move with the particles.
    Therefor I want to animation the offset, the reason being it drives the taper. However if I feed SoundKeys into the offset, they are out of phase:
    Expression Offset:
    1/30*2*Math.PI*thisComp.layer("Keys").effect("Sound Keys")("Output 1");
    Hence the angular momentum must be different. But why?
    This might all seem abstract so I’ll attach a picture of what I am wanting to do:
    Ness Lange replied 5 years, 6 months ago 1 Member · 1 Reply
  • Ness Lange
    March 12, 2021 at 11:58 pm
    So it just harmonizes with:
    f*100*thisComp.layer("Keys").effect("Sound Keys")("Output 1");
    Don’t know why exactly this relation. Probably because of the way the’offset’ is defined.
