Activity Forums DVD Authoring How to master out a DLT from scenarist with edvd folder on it. URGENT!!!
  • How to master out a DLT from scenarist with edvd folder on it. URGENT!!!
    Posted by Pelle Ferner on April 6, 2006 at 8:47 pm
    I need to master out a DVD-9 from scenarist with a edvd4 material on it to a duallayer DLT mastertapes.
    Is this possible in scenarist? In that case how do I do?
    When I try to put my edvd image file in enhanced scenarist project and master i out to a image file and run the image file as a virtual disc. It says that my edvd file is not original and illegal.
    Do I need a ROM Formatter to lay out a edvd4 enhansed duallayer disc from scenarist to DLT?
    How do you do this?
    best regards. / pelle
    Pelle Ferner replied 20 years, 5 months ago 1 Member · 1 Reply
  • Pelle Ferner
    April 7, 2006 at 7:55 am
    Here is the solution from sonic support.
    If anyone having this troubble.
    Hello Pelle,
    Go to the layout editor and make sure that you set the disk info in the properties to unchanged 30 character type files, and not one of the 8.3 types. Set the layer break after you have included the rom content so it gets counted in.
    Mux the project to a Video TS, do your eDVD authoring, set the output file types to 30 character and then point ot the eDVD files as rom content, Then set your layer break. Then write a disk image and DLT.
