Activity Forums Maxon Cinema 4D how to “mask” 3D objects
  • how to “mask” 3D objects
    Posted by Manny Rellesiva on July 17, 2008 at 9:13 am
    I have a 3D text and would like to animate each stroke of the letter so that it would appear as if it is being written. If this was done in After Effects, I could use paint effect, etc…In cinema 4D how would you do this? Im on wndows xp pro im using cinema4d R10. thanks in advance.
    manny
    Josh Crews replied 17 years, 5 months ago 4 Members · 4 Replies
  • Zach Gunter
    July 17, 2008 at 3:14 pm
    do you have sketch and toon? if you do here is what you do
    1. In your Materials make a Sketch material (
    2. Make a text spline of your text
    2a. In the text attributes under object, you’ll see separate letters, click it.
    2b. Make and copy enough extrude NURBS as your letters and drop each letter on each extrude
    3. Double click on your Sketch Material ( In main on control level make it advanced)
    3a. Make your Material Lines how you want,(pen, Pencil, etc)
    3b. go down to the animate option and click draw( and set up how you want in to draw in stroke order.
    3c. On draw speed make your option End Frame
    with me so far……
    4. Now…Copy that sketch material the number of letter you have
    4a. Drop a sketch material on each of the extruded NURBS in sequence.
    (In your Materials)
    5. Double Click on your first Material, in animate, set your beginning and end frame
    5a. double click on your second material, in animate, set your start frame to 20
    5b. ” ” ” ” ” ” ” ” , set your start frame to 40
    6. Do a preview render and enjoy.
  • Zach Gunter
    July 17, 2008 at 3:35 pm
    here are two other ways, if you don’t have sketch and toon.
    1. Make a quicktime of your Animation in After Effects.
    1a. open C4d, make new material, in color on texture, to the right of texture you see the little dots.
    1b. click the dots and select your video
    1c. make a shape, plane, or whatever, and drop your material on that.
    1d. if you want the text only, go back into your material, under alpha, select your quicktime again.
    This one is harder, and more time consuming
    2. Make a text spline and make a extrude nurb
    2a. click c to make it editable
    2b. go to object face mode. it’s on the left of you screen the 4 squares with 3 dots on them click it
    2c. at the bottom of your screen, right below your timeline there is a grid of 9 dots. click it
    2d. now you can key frame the letter building itself.
  • Randy Johnson
    July 17, 2008 at 8:15 pm
    This one can be done a few more ways too…depending on how you made the text and how detailed it needs to be…
    -first I would try using a text spline in a sweep nurbs and keyframing the “end growth” in the attributes.
    This works well with some fonts but not all.
    Or
    the next thing I would try is animating the Alpha channel in the texture…this is not so bad with square fonts but can be boring to do since you are playing with a gradiant and it is very dependent on the texture…ect.
    There are more ways but these are the two i would try first.
    /Randy
  • Josh Crews
    March 27, 2009 at 1:21 am
    I’m glad I found this post. I’ve been researching crazy for ways to animate text like this.
    Randy, you’re a genius. Animate the gradient on the alpha channel. Why didn’t I think of that?
    Thank you.
