Activity Forums Square Box CatDV How to mark unused footage
  • How to mark unused footage
    Posted by Carsten Orlt on December 4, 2011 at 10:43 pm
    I’m trying to work out how I could make a list/create a new catalogue from a set of clips with only the footage I HAVEN’T used in a sequence.
    Idea is that after I finish a film I would like to mark all ‘not-used’ footage to make it available for stock footage library use.
    Tricky bit is that within a clip several sections could be used and also unused. I know that I can mark all clips used in a sequence and therefor can get the reverse selection being the unused whole clips. BUT often there are good bits in a clip that is partly used. So marking the whole clip would make me loose these bits.
    Any idea how this could be done with CatDV?
    Any help is much appreciated
    Carsten
    Carsten Orlt replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
