Activity Forums Apple Final Cut Pro Legacy How to make timeline audio files the same names as newly named audio files in Finder?
  • How to make timeline audio files the same names as newly named audio files in Finder?
    Posted by Daniel Masciari on May 13, 2013 at 6:55 pm
    Hey all,
    So I’m going to try and word this as accurately as I can. So I edited a project in FCP 7, and before I named files, due to time constraints, I edited the project. I now duplicated all of the audio files in the Finder and renamed them by shot, take, etc., but of course, this doesn’t change the names of the files in the timeline. I want to be able to export an OMF for the sound editor using the newly named files (the shot, take, etc.) in the timeline. Is there a fast way to do this..relatively fast?
    Best!
    Sincerely,
    Daniel
    Daniel Masciari replied 13 years, 3 months ago 2 Members · 2 Replies
  • Nick Meyers
    May 15, 2013 at 11:19 am
    “I now duplicated all of the audio files in the Finder and renamed them by shot, take, etc., but of course, this doesn’t change the names of the files in the timeline”
    DUPLICATING the clips was a mistake
    if you did not dupe he clips, the timeline instances of the clips would have followed your name changes
    well, they SHOULD have if they had the proper master / affiliate relationship
    “Is there a fast way to do this..relatively fast?”
    start again.
    as you have already made most decisions about what to call the clips,
    doing it a second time should be a bit quicker
    if you want to you can simplify the job by only working on the clips that are in the timeline.
    i would advise you to COPY the edited sequence into a NEW PROJECT
    select the sequence in het b rouser, and got TOOLS MENU > Create Master Clips.
    this will give you just the used clips, plus the maser affiliate relationship would work.
    nick
  • Daniel Masciari
    May 15, 2013 at 4:17 pm
    Nick,
    thanks so much! This is very helpful. Have a great day!
    Best,
    Daniel
