Activity Forums Apple Final Cut Pro Legacy How to make this transition?
  • How to make this transition?
    Posted by Hunter Stevens on August 3, 2008 at 4:34 am
    Hi, I’m trying to create a transition that I used frequently on Avid, but can’t seem to figure out to make it happen in FCP. Here it is…
    It starts with a simple horizontal push between 2 shots (easy enuf), then in Avid I’d just add a paint effect to make a horizontal blur (or sapphire plug if avail) on a blank video layer above the push which would blur the push as well.
    I can’t add anything other than footage to tracks in FCP right? So any ideas on how to create this?
    Thanks much.
    Hunter Stevens replied 18 years, 1 month ago 7 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    August 3, 2008 at 12:47 pm
    Try adding motion blur to the moving shots. It’s in the Motion tab of each.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Chris Poisson
    August 3, 2008 at 12:59 pm
    Hunter,
    Look at the Eureka! package, it has a nice blur dissolve.
    Have a wonderful day.
  • Tom Wolsky
    August 3, 2008 at 3:03 pm
    Peter Wiggins has a new object based transition that sounds like it will wok for you.
    https://peterwiggins.com/content/view/43/33/
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Rafael Amador
    August 3, 2008 at 3:57 pm
    Hi Hunter,
    There are some Blur transitions in a free package call “Stib’s plugins”. Just type it in Googles.
    Andy Mees have something too:
    https://web.mac.com/andymees/Free_and_Easy/main/main.html
    rafael
    http://www.nagavideo.com
  • John Fishback
    August 3, 2008 at 9:09 pm
    Check out CHM plugins: https://www.cgm-online.com/eiperle/cgm_e.html
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.4, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w 192 Digital, SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Stephan Walfridsson
    August 4, 2008 at 9:21 am
    [Hunter Stevens] “I can’t add anything other than footage to tracks in FCP right?”
    What you have to do in FCP is to nest the two clips with the push transition, creating a sub timeline, and add the blur effect onto the new nested clip. The “Nest Item(s)” option in the Sequence menu does this for you.
    It’s similar to the Step In/Out feature in Avid where you build effects using deeper levels of timelines. Like in the keyer where you have the matte on one track och foreground and background on the other tracks.
    Unfortunately this does make it more complicated if you need to trim the incoming or outgoing shot or would like to replace them. And it also creates tons of tiny sequences in the browser.
    I sure wish they could implement an easier way to add effects to tracks or across clips/transitions.
    /Stephan
  • Hunter Stevens
    August 5, 2008 at 7:21 am
    Thanks Stephan that’s exactly what I needed to know! And thanks for all the plugin ideas as well.
    Never let the odds keep u from doing what u know in ur heart u were meant to do.
