Activity › Forums › Adobe After Effects › how to make this effect?
  • Kalleheikki Kannisto
    March 21, 2016 at 7:31 am
    That is a refraction effect. I don’t remember if you can do that in pure AE, but perhaps the glass effect does refraction.
    The original image might be as simple as a couple of circles or a wiggled path, and the whole thing is put through a refraction effect — as if seen through a piece of mottled glass — at varying smoothness settings.
  • John Cuevas
    March 21, 2016 at 1:57 pm
    I think a combination of fractal noise & find edges should get you most of the way there.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Evans
    March 21, 2016 at 2:19 pm
    Draw some shapes, throw Turbulent Displace on it, increase the amount to around 1000, play with settings.
