Activity › Forums › Adobe After Effects › How to make this animation
Posted by David Hueso on November 17, 2009 at 5:00 amHow to make this animation in After Effects? Or is 3d?
I'm talking about trees…Not from the file.http:/ / adsoftheworld.com / media / tv / honda_insight_hybrid_multiplicity
David Hueso replied 16 years, 10 months ago 3 Members · 4 Replies -
Michael Szalapski
November 17, 2009 at 5:17 amIt looks like the tree shapes are revealed using videos of ink in a tank of water on another layer as a luma matte. Or something similar.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
David Hueso
November 17, 2009 at 5:30 amosea tu crees que simplemente son ilustraciones ..que se van revelando con luma matte…
gracias -
Ryan Hill
November 17, 2009 at 8:39 pmI think it looks similar to this:
https://library.creativecow.net/articles/hansen_jaysen/growing.phpWith a dozen bunches of leaves for each tree being scaled up simultaneously. If I were to try this, I’d probably use expressions to tie the scale and rotation of each bunch of leaves to a single slider. They might also have some bunches that are parented to the first collection of bunches.
So, you’ll spend a lot of time constructing the tree, but once you have it, you can animate it pretty easily. If you’re doing a lot of trees, you might want to add some other properties that can be adjusted so you can make each tree slightly different just by changing some values.
