Activity › Forums › Adobe After Effects › how to make sticky effect on solid/shape layer?
Posted by Bas V breugel on October 2, 2015 at 7:43 pmIs it possible to make this effect (without frame by frame mask path) ?
https://codepen.io/lbebber/pen/OPjxZLAshish Gupta replied 10 years, 11 months ago 4 Members · 3 Replies -
Tudor “ted” jelescu
October 3, 2015 at 7:35 amYou can use shapes for the dots, animate them and pre-compose and then apply Refine Hard Matte to get the sticky effect. The only issue with this is that you will get a feathered edge, so once you get the animation that you need done, duplicate the layers several times to get a sharper edge.
Tudor “Ted” Jelescu
Senior VFX Artist -
Kalleheikki Kannisto
October 4, 2015 at 8:58 pmGaussian blur plus threshold would also give a very similar result.
Ashish Gupta
October 5, 2015 at 10:10 amAfter blurring shape layers you can simply use a simple choker to correct the feathered edge.
Ashish Gupta
Motiongraphics artist and 3d generalist
