Activity Forums Adobe After Effects How to make shapes/text explode in different directions?
  • How to make shapes/text explode in different directions?
    Posted by Ryan Gibbs on November 10, 2016 at 3:05 pm
    I’m trying to make these letters go off screen as if someone is pushing them from the middle outwards:
    What would be the best way of doing this? I’ve tried hand-animating, but it doesn’t look natural.
    (Side note: The letters are individual images I created in photoshop and brought in as .png’s)
    Any help would be appreciated! Thanks 🙂
    – Ryan.
    Ryan Gibbs replied 9 years, 10 months ago 4 Members · 6 Replies
  • John Cuevas
    November 10, 2016 at 3:14 pm
    You can do that using the shatter effect.
    https://library.creativecow.net/articles/unguren_ben/shatter.php
    https://library.creativecow.net/articles/mize_rob/AE-Shatter-Effects/video-tutorial
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ryan Gibbs
    November 10, 2016 at 3:29 pm
    Oh, I wasn’t expecting that to work! Cheers 🙂
    – Ryan.
  • Ryan Gibbs
    November 10, 2016 at 3:42 pm
    I’ve run into a bit of a problem, it’s splitting the inside and outside:
    – Ryan.
  • Soham Jani
    November 10, 2016 at 5:25 pm
    I believe Andrew Kramer has a tutorial relating to shattering somewhere on his website?
    \”It\’s all around us Neo, temporary constructs of time…..\”
  • Michael Carter
    November 10, 2016 at 9:28 pm
    Is each letter two files? That could be your problem. The plugin is randomly scattering everything.
    I’d find a way to bind them together if so – precomp each letter, for instance. Or do a set of PNGs where the white stroke and the inner color are one file.
  • Ryan Gibbs
    November 14, 2016 at 2:14 pm
    I found out that shatter uses alpha channel to calculate the shatter, so as soon as I duplicated the comp, and made the second comp a solid red (instead of white+red), it worked perfectly.
    But thanks for your help, I really appreciate it 🙂
    – Ryan.
