Activity › Forums › Maxon Cinema 4D › How to make shadows from transparent objects “dye”?
  • How to make shadows from transparent objects “dye”?
    Posted by Adolfo Rozenfeld on July 8, 2005 at 2:12 am
    Hey, all.
    Does anybody know how to make colored shadows, ie, shadows acting as projections after “dyeing” with the colors of transparent materials?
    I am doing an animation with sem-transparent objects, and even though the “transparency” option is turned on for the shadow casting light source, the shadows are still black.
    Any advice?
    Many thanks!
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
    Adolfo Rozenfeld replied 21 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 8, 2005 at 4:41 am
    Just some quick testing and I can’t make it not have colored shadows except at very small transparencies. Can you post a test file?
  • Adolfo Rozenfeld
    July 8, 2005 at 8:22 am
    Thanks for your reply, Brian.
    The shadows just became colored when I assigned the animated texture in the Transparency channel of the material. I guess that if the transparency channel is white, it doesn’t produce colored shadow no matter how strong the transparency.
    Now It works, but you know what? It probably looked better when shadows were black 🙂
    Thanks again
    Adolfo Rozenfeld
