Activity Forums Maxon Cinema 4D How to make selected polygons a separated object?
  • How to make selected polygons a separated object?
    Posted by Miem Chan on March 12, 2006 at 1:25 pm
    How to make a selected set of polygons a seperate object?
    Example :
    Assume I have a cube object and I selected two neighboor sides (two polygons). How can I detach these two side from the rest of the cube so that I end up two objects; one consists of two polygons and the other object consists of 4 polygons?
    Adam Trachtenberg replied 20 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 12, 2006 at 9:52 pm
    [Miem Chan] “How to make a selected set of polygons a seperate object?
    Example :
    Assume I have a cube object and I selected two neighboor sides (two polygons). How can I detach these two side from the rest of the cube so that I end up two objects; one consists of two polygons and the other object consists of 4 polygons?”
    There are two ways:
    * Function>Split creates a new object from the selected polys, but does not delete then from the original (must be done manually);
    * Function>Disconnect followed by Function>Explode Segments.
