How to make scaling proportionate to wiggle?
Hi. I’m using the wiggle tool in After Effects CS5.5; I noticed when I used the wiggle this occured:
https://gyazo.com/8134d012ebe9a926f492417008500eed
I made the alpha channel red so you could see it better. I’m sure there’s a way to fix this, what is it? Thank you in advance.
