Activity › Forums › Apple Final Cut Pro Legacy › How to make “real” subclips out of the timeline?
  • How to make “real” subclips out of the timeline?
    Posted by Jan Gassmann on February 21, 2009 at 11:51 am
    Dear Friends
    I have a quite simple problem – it should be possible to solve it. If I arrange my clips in the timeline and use the In and Out – point to make subclips, I get a new subclip in the browser, but it is still a sequence. So If I ll start to edit, I ll get a sequence with a lot of nested sequences in it (not mentioning that doubleclicking will always link back to the sequence, so trimming is a pain). By the way: I m arranging the clips in the sequence, because sometimes I have a continuing sound, but the cameraman stopped the rolling twice. So its very easy to work like this in FCP.
    So it would be great to convert the sequences into “real” subclips (There is also an issue, that I need to activate more channels in the sequence settings to not get a stereomixdown of my audiochannels).
    I know I can do this through exporting with MediaManager. But it would be cool, if I could to it with a kind of simple conversion…
    Thanks in advance, hope it wasn’t to confusing
    Best from germany
    Jan
    Wendy Conquest replied 14 years ago 8 Members · 10 Replies
  • 10 Replies
  • David Bogie
    February 21, 2009 at 4:05 pm
    You must select the clip only to obtain a subclip. I’m not watching over your shoulder but it sounds like the sequence is selected in the browser so that’s what gets subclipped.
    The only reasonable way to get useful subs is to export them as new media and reimport them, which, in any decent NLE, would be a one-button operation, if it was necessary at all, which it shouldn’t be.
    There’s a somewhat dated article on kenstone.net about the family of FCP clip types.
    The main issue is your (and my) definition of subclips differs wildly from Apple’s and we’re all stuck with the official version. We must conform.
    My definition of sublclip goes back to Media 100 which was intuitive, flexible, and functional. I see none of those attributes in FCP’s weird subclip routine.
    bogiesan
  • David Mcgiffert
    February 21, 2009 at 4:27 pm
    Boogie,
    You are so right. There are many things I miss about
    my Media 100 system and that is definately one of them.
    (another is reading your posts on the M100 board,
    some of those were historic)
    It astounds me that a program with as much depth as
    FCS can have such startling lapses.
    I love the program but why not make changes that
    improve the basics?
    It’s easy to criticize of course, but improvements like
    this should not have to fall on deaf ears.
    All the best
    David
  • Jeremy Garchow
    February 21, 2009 at 5:25 pm
    [David McGiffert] “It’s easy to criticize of course, but improvements like
    this should not have to fall on deaf ears. “
    and it doesn’t. Unfortunately, FCP cannot make subclips from multiple clips, ti can only make it from a single clip so you are forced to export any clips as new hard media and be sure to leave yourself handles in case you need them. I encourage everyone to request this feature from apple’s feedback page as this would help a whole host of workflows:
    https://www.apple.com/feedback/finalcutpro.html
    M100 ALWAYS had superior media management. It was built right in to the system. Unfortunately, it is not in FCP but hopefully that will change someday.
    Jeremy
  • Lars Fuchs
    February 21, 2009 at 6:17 pm
    Once you’ve got all your subclips (even though they are still sequences) in a bin, select and batch export them all using File->Batch Export commmand. Export them as qt files but don’t make them self-contained, make them reference files. They will export much quicker this way. Then simply drag all the completed files you’ve just exported back into FCP. They wont relink to your original media, so you should be sure to include handles in the export. But it shouldn’t take very long, and wont really take up any significant disk space.
  • Jeremy Garchow
    February 21, 2009 at 6:27 pm
    [Lars Fuchs] “Export them as qt files but don’t make them self-contained, make them reference files. They will export much quicker this way.”
    Ah, but see in this case, it’s best to export as hard media to take to Color and any other application. I normally export ref movies, but this is a case where self contained can really save your butt. If any of the render files or other media go away, you will be left with no reference movie and you will have to recreate them. In my opinion not that it matters much, but if you are going to reimport media back in to FCP to edit with, it’s best to export self-contained.
    Jeremy
  • Lars Fuchs
    February 21, 2009 at 8:17 pm
    [Jeremy Garchow] “If any of the render files or other media go away, you will be left with no reference movie and you will have to recreate them.”
    That’s a good point about the render files. I hadn’t thought about that. In this case Jan mentioned trying to create clips from dual system shoots, so I don’t think rendering is an issue. This is the source media for the edit, so its likely to stay online for the edit. However, if he media manages the new clips, FCP will create self-contained files.
    It also occurred to me that Jan could try to create a group of multiclips from the separate picture and sound using the ‘make multi-clip sequence’ command (and uncheck the “automatically edit multiclips into new sequence” box). The resulting multiclips should be subclippable in the way Jan is looking for. It might be necessary to set the aux-tc on the various elements first, though.
    I’ll be able to do a test of that on Monday and I’ll let you know.
  • Alex Gollner
    February 21, 2009 at 9:27 pm
    If a long interview has been digitized as a single clip I sometimes slice it up on the timeline and use the media manager to make a new project with that sequence using Copy for the media but without ‘Include Master Clips Outside Selection,’ I usually add a few frames for handles.
    I didn’t use a Media 100. How would you like subclips to work?
    alex4d
  • Jeremy Garchow
    February 21, 2009 at 11:08 pm
    [Alex Gollner] “How would you like subclips to work? “
    So you could add multiple clips to make one sub clip. With Media100 you don’t have to export and reimport, you simply told it what clips to make a sub clip and it did it. It would also keep track of the individual time code for all clips contained within. It was very simple and smart.
    Jeremy
  • Carsten Orlt
    February 22, 2009 at 5:30 am
    As all the other have stated: can’t be done without export – reimport.
    ! Only thing to be aware of is that you’ll loose the TC reference to the original clips !
    Allow me a tip for a workaround (well not really but kind of) I’m using sequences a lot to make myself select reels from which I cut my final version.
    Copy – Paste is really quite fast way of working between seq. And you can select anything between the in and out point in a sequence regardless of number of clips and where they are positioned on the timeline (only limit is the track selection) by pressing OPT-A. then copy, switch to your master seq and paste. All original clip tc and reel data maintained!
    Also remember that you can link any clips on the timeline by selecting them and press COMMAND-L.
    Hope this helps. (if you didn’t know them already)
    Carsten
  • Wendy Conquest
    September 19, 2012 at 11:18 pm
    I finally found the answer to my problem. Thank you!
