Activity › Forums › Maxon Cinema 4D › How to make object fall from the sky while attached to a string?
  • How to make object fall from the sky while attached to a string?
    Posted by Evelyn Wandernoth on July 7, 2019 at 11:43 am
    Hey all,
    I’ve got an idea for a short that involves a hatch in the ceiling opening after a few seconds, and a donut on a string falling down in front of my subject – then dangling mid-air afterwards.
    I’m not quite sure how to get my desired effect. I’ve tried hair effects with constraints and dynamics, as well as implementing a spring – however it’s not quite giving me the effect I’m looking for, especially since the spring works immediately, and not after a bit of a delay in a video (giving time for the hatch to open and whatnot).
    Any advice would be highly appreciated! Thank you
    Jim Scott replied 7 years, 2 months ago 2 Members · 1 Reply
  • Jim Scott
    July 10, 2019 at 3:42 pm
    To control when the dynamics start, and thus when the spring begins to affect the donut, keyframe either the “Enabled” setting or the “Dynamic” setting (from “Off” to “On”) of the donut’s dynamic’s tag.
    Edit: You could also keyframe the “Enabled” setting of the spring so that the donut starts falling before the spring begins to take affect.
