Activity › Forums › Adobe After Effects › how to make names of footage show up over video?
Posted by Jeremy Webb on December 13, 2006 at 12:49 amis there a way (maybe a script or something) to have the clip that appears have it’s name automatically appear on render. like a timecode reader that reads file names?
Jeremy Webb replied 19 years, 9 months ago 3 Members · 6 Replies -
Steve Roberts
December 13, 2006 at 1:33 amYou can make a text layer, and for its source property, use an expression that refers to the name of the relevant footage layer:
thisComp.layer(“whatever.mov”).name
… where whatever.mov is the name of the footage layer.Or you could use:
thisComp.layer(index+1).name
… assuming that the footage layer is immediately below the text layer. The text layer may be layer 5 (index), while the footage layer would have to be layer 6 (index + 1).If that doesn’t suit your needs, let us know …
Jeremy Webb
December 13, 2006 at 5:18 pmthanks steve, that second one is almost exactly what i need, now is there a way so that it will look at any layer below it? (not just the one directly below it. for example i bring in a fcp timeline through automatic duck, then i want to add a text layer above all of layers and have it display each clip as they come up? is there a way to make this work?
Jeremy Webb
December 13, 2006 at 6:14 pmthe reason i want this, is that i want to export a quicktime with the names in it for other people to use as a reference. there will only be one layer on at a time as it is more of an edit than a layered comp.
Steve Roberts
December 13, 2006 at 9:52 pmAh. I can’t think of a way to use one text layer that will use the name of the currently visible layer as a source. You could, however, use a text layer for each footage layer (with just the one expression), then adjust the text layer’s in/out points to match that of the footage layer below.
Dan Ebberts
December 14, 2006 at 4:28 pmThis expression (for a text layer’s source text) gives the name of the source of the current active layer (if it has no source it gives the layer name). Apply to a text layer at the top of the layer stack.
txt = “”;
for (j = 1; j <= thisComp.numLayers; j++){ if (j == index) continue; L = thisComp.layer(j); if (! (L.hasVideo && L.active)) continue; if (time >= L.inPoint && time < L.outPoint){ try{ txt = L.source.name; }catch(err1){ txt = L.name } break; } } txt Dan -
Jeremy Webb
December 14, 2006 at 5:01 pmthanks dan, that was exactly what i needed. i owe you a beer
