Activity Forums Apple Final Cut Pro Legacy How to make multiple JPEGs from single frames in FCP
  • How to make multiple JPEGs from single frames in FCP
    Posted by Jodie Myers on May 16, 2012 at 6:18 am
    I know how to make a JPEG from a single frame in FCP, but how do I create 300 JPEGs from 300 single frames w/o having to go through the 3 step process for each one?
    I have a project to hand in by the 17th, so I hope someone can help me out sooner than later.
    Jodie Myers replied 14 years, 4 months ago 2 Members · 2 Replies
  • Neil Patience
    May 16, 2012 at 7:21 pm
    You need to use Export Using Quicktime Conversion.
    Then select Format – Image Sequence. Select format for JPG and the correct frame rate.
    Export and you will get 300 JPEG frames automatically.
    best wishes
    Neil
    http://www.patience.tv
  • Jodie Myers
    May 16, 2012 at 7:27 pm
    Thanks! I actually figured it out last night, what a life saver!!
    Cheers,
    Jodie
