Activity › Forums › Adobe After Effects › How to make logo letters animate individually and together?
Posted by Brad Hebert on November 19, 2012 at 8:46 amI’m pretty new to AE. I have a logo. The first letter is an image and the rest is text. I’m guessing this is a common thing to do:
I’d like to make it all 3D (extrusion?). And I’d like to have all the individual parts fly in separately and lock into the logo, pan the full logo around and then explode/shatter it.
I’m learning that there are a lot of ways (some better than others) to do the same thing in AE. Is there a standard way to do what I’m looking for?
John Cuevas replied 13 years, 9 months ago 3 Members · 9 Replies -
Vishesh Arora
November 19, 2012 at 9:32 amBrad
Shatter Simulation can be used in many ways as per the requirement.
Watch this tutorial on Shatter Simulation:https://www.youtube.com/watch?v=ekAkhDLNIDM
For creating Extruded Logo:
https://www.youtube.com/watch?v=VWMe7HkEi5w
https://www.youtube.com/watch?v=3xwNRwND9w4
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Brad Hebert
November 20, 2012 at 12:41 amActually, I tried importing an AI file, but there is no “create shapes from vector layer” option. Is that because I’m using CS5.5? If so, is there something else I can do?
Brad Hebert
November 20, 2012 at 1:02 amAnother question:
How do I choose when the shatter happens? I want to reverse shatter the logo in place, hold it for a few seconds, then shatter it away.
John Cuevas
November 20, 2012 at 12:36 pmAdd you layer to a composition and select the layer. Now on the menu bar go to Layer > Create Shapes from Vector Layer.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Vishesh Arora
November 20, 2012 at 12:46 pmBrad
“Actually, I tried importing an AI file, but there is no “create shapes from vector layer” option. Is that because I’m using CS5.5? If so, is there something else I can do?”3D Extrusion feature is available in CS6 version only. You have to any other 3D application like Cinema 4D to extrude shapes from .ai file.
“How do I choose when the shatter happens? I want to reverse shatter the logo in place, hold it for a few seconds, then shatter it away.”
Shatter effect can be controlled by Key-Framing the Radius Parameter in it.
Steps:
1. Go to Effects Control Panel.
2. Twirl down Shatter effect.
3. Twirl down Force 1.
4. Bring the radius value to Zero.
5. Now key-Frame the Radius say at 3 sec and at 3 sec 1 frame bring the radius value back to its original say 0.5.For reverse animation:
1. Select the Layer in Time Line.
2. Right Click on it and go to Time and select Time-Reverse Layer.Vishesh Arora
Films RajendraBlog:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
John Cuevas
November 20, 2012 at 12:59 pmFirst here are a couple of tutorials on using shatter(it can be a bit over-whelming):
This tutorial is quite old, but shatter hasn’t changed in 10 years so it’s still relevant: Basic Shatter: Introduction to the Shatter Effect
A new Tutorial from Rob Mize: Shatter-Mation in After Effects
To answer your question though, a layer shatter when it is hit by a 3D force. When you first apply shatter you will get a wireframe plus forces view. The blue lines are the force hitting your layer like a wrecking ball causing it to break up. By twirling down the force parameter you can control when your layer is hit, where it’s hit and how it’s hit.
You can’t reverse shatter a logo per se, you need to shatter the logo and precomp the effect. Now you can apply a Layer > Time > Time Remap to have the shatter reverse and explode out again.
I made an example project illustrating how shatter works and how you would time remap it. Take a look at the tutorials/my project and if you have any more questions, come back and ask.
John Cuevas
December 6, 2012 at 12:33 pmGlad I was able to help
