Activity Forums Adobe After Effects How to make huge stroked path?
  • How to make huge stroked path?
    Posted by Eyvind Dekaa on October 28, 2013 at 3:58 pm
    I’m trying to make a stroked path that will show a curve for the global temperature from million years ago to present time.
    Actually I’m trying to stitch 4 curves together that each have a scale of millions, thousands, hundreds and tens of years.
    I would like to make assemble into one curve that I can zoom in and out of.
    Would that be possible?
    What about the stroke, how do I make the thickness of the stroke uniform in each end of the curve.
    All good ideas are highly appreciated!
    TIA
    Eyvind
    (Copenhagen)
    Eyvind Dekaa replied 12 years, 10 months ago 3 Members · 6 Replies
  • John Cuevas
    October 28, 2013 at 4:48 pm
    It seems you could create this curved stroke/timeline in illustrator, save it as an AI file, bring it into AE, turn on continuous rasterization and zoom and pan however you wanted.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Roland R. kahlenberg
    October 28, 2013 at 6:24 pm
    A Shape Layer should make this easy. Simply draw your path with the Pen Tool. Switch off the Fill property and adjust Stroke Width and its other properties to suit your needs. Shape Layers are Continuously Rasterized – no issues with pixelation when you zoom into it.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Eyvind Dekaa
    October 28, 2013 at 6:33 pm
    About animation: Yes, it would be nice to be able to have an animated stroke. Taper in and out.
    But not a cardinal request.
    I did try to scale and animate 4 jpg’s in Premiere, but that looked awful.
    About Illustrator: My skill there is very limited there to say the least.
    Could be that I could make a tiff in Photoshop, but then again I have hoped AE could do the deed.
    Anyway, big thanks for your suggestions! 🙂
    Best regards
    Eyvind
  • Eyvind Dekaa
    October 28, 2013 at 6:35 pm
    Thank a lot.
    I will have a look into Shape layer.
    (Never used it before)
    If it works out I’ll will tell here!
    Best regards
    Eyvind
    October 28, 2013 at 6:40 pm
    No tapering with a Stroked Shape Layer. Stroke width also affects the entire path. To have variable sized strokes, create separate Shape Paths and set Stroke width accordingly.
    HTH
    RoRK
  • Eyvind Dekaa
    October 28, 2013 at 10:42 pm
    I believe the Shape Layer did the trick.
    There I could transform the path.
    And it’s also possible to keyframe the Stroke Width.
    That way I should be fine:
    https://www.eyvind.dk/Storage/Combined.m2v
    Should anybody be interested in the global temp curve from ½ mill years ago until present time, have a look here:
    (Climate changes seems an old thing) 😉
    https://www.eyvind.dk/Storage/Zoom_Creativ_Cow_ver.aep
    Again, huge thanks for your suggestions!
    Eyvind
    (Copenhagen)
