Activity › Forums › Maxon Cinema 4D › How to make grass not go through objects in Cinema 4d?
  • Adam Trachtenberg
    June 9, 2014 at 4:06 pm
    There’s a number of ways you could improve the dynamics here, but it will seriously slow down the playback and render. For example, you could increase the steps in the hair dynamics settings so the collisions are sampled more frequently. You could enable “surface to hair” in the Hair forces settings simulate wind from the butterfly wings. You could use hair collisions instead of guide collisions. Etc.
    However … I think the best way to address it is to cheat. Render a separate pass with just the butterfly and comp that over the render with the grass and butterfly. You may need to roto a bit to preserve the grass overlapping the wing edges.
  • Petkov Stankov
    June 9, 2014 at 4:09 pm
    As soon as I get home I will try that. Thanks for the reply.
  • Petkov Stankov
    June 10, 2014 at 10:45 am
    That actually did the trick. I saw that by selecting “Hair surface” from the Force tab that it’s making a nice effect like the wings are influencing the grass. But it’s influencing it too hard. Any thoughts on how to make it influence less?
  • Adam Trachtenberg
    June 10, 2014 at 2:52 pm
    You can adjust the force and radius in the hair collision tag.
  • Michael Clark
    June 18, 2014 at 1:49 am
    composite seems like quickest way.
  • Petkov Stankov
    June 18, 2014 at 7:23 am
    Thanks a lot for helping out guys. I’m really grateful for this community.
