Activity › Forums › Apple Motion › How to make FCPX generators act as normal footage, so you could trim, dived with blade, etc.
  • How to make FCPX generators act as normal footage, so you could trim, dived with blade, etc.
    Posted by Jonas Bengtsson on December 13, 2013 at 3:08 pm
    Is it possible to make FCPX generators act as normal footage, so you could trim, dived with blade, etc.
    We shot infront of a green screen, with two tractions points and 1-5 minuets takes.
    Very basic , little zoom in and out, some small camera motion on a tripod.
    I make a FCPx generator with two point Match Move and drop zon for the background.
    In FCPX, if I want to trim and cut with blade it doesn’t act as a regular footage, it shrinks, stretches or divides in two clones but always from first to last frame.
    The work around is to put it in a compound clip.
    Have tried with build in and out markers.
    Is it another way?
    Jonas Bengtsson replied 12 years, 9 months ago 3 Members · 5 Replies
  • Mark Spencer
    December 13, 2013 at 3:37 pm
    Adding a Loop end marker would force the duration to be fixed when trimming in FCP X.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jonas Bengtsson
    December 15, 2013 at 4:24 pm
    Better but I can just trim and blad “out” point, if i change the “in” point it always strarts on frame 1.
  • Nikolas Bäurle
    December 15, 2013 at 8:58 pm
    You can make a compound clip, then simply cut or retime that. works very well. I do that usually when I need to change the speed of certain animations, and don’t feel like opening motion again.
  • Nikolas Bäurle
    December 15, 2013 at 11:29 pm
    I just realized that I had read your first post too quickly. You’ve of course already used compounds.
  • Jonas Bengtsson
    December 16, 2013 at 8:46 am
