Activity Forums Apple Motion How to make explosion “churn” for longer?
  • How to make explosion “churn” for longer?
    Posted by Josh Bass on July 7, 2013 at 10:02 am
    Hi. Another one of those questions I can’t figure out by Googling or trial and error. . .
    So I’m using one of the explosion particle emitters. What I’d like to do is basically slow it down, so that once it “blooms”, it doesn’t “burn out” and fade as fast. Now, I looked at the keyframes to see what was animated, and played with those parameters (making the distance between keys longer), but the results I got from that were that only after everything turns white does it kind of stick around and then abruptly cut out.
    I’d like it to bloom/blossom as normal, and the roil/churn for a while, and then fade. Any way to make this happen? Thanks.
    Josh Bass replied 13 years, 2 months ago 2 Members · 2 Replies
  • Mark Spencer
    July 8, 2013 at 3:42 pm
    You can try cloning it, turn off the source, and retime the clone.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Josh Bass
    July 8, 2013 at 3:54 pm
    Thanks. Can you enlighten me as to why I need to clone it instead of just retiming the original? I guess I’m not too familiar with the cloning thing.
    I forgot to mention I did try adding a retiming behavior to it that it didn’t even seem to let me add at all. Do clones have different properties than originals?
