Activity Forums Adobe Illustrator How to make entire path object warp as it appears after Effect Warp Arc.
  • How to make entire path object warp as it appears after Effect Warp Arc.
    Posted by Lars Ervik on April 10, 2014 at 7:34 pm
    Hi.
    I have a path object that I want to export to Roland Cutstudio for cutting vinyl decals.
    I need to have the object arced to get the shape I need. So I used the Effect, Warp, Arc to get the shape I need.
    But the problem is that the paths stay unchanged as a straight baseline. Only the Appearance on the screen change. So when I use the Roland Cutstudio plug-in, the paths are exported without the arc-effect. You can see in the lower left hand corner on the screenshot, how the Roland Plugin sees the object, without the arc effect)
    So my question is, How can I arc the path object in Illustrator so that also the PATHS arc in the same way as it the Appearance on the screen?
    Lars Ervik replied 12 years, 1 month ago 2 Members · 2 Replies
  • Vincent Rosati
    April 10, 2014 at 8:51 pm
    Try – Object / Expand
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Lars Ervik
    April 11, 2014 at 2:32 pm
    Perfect!! That wasexactly the solution I was searching for! Thanks a million /Regards, Lars
