Activity Forums Adobe After Effects Expressions How to make each option in a dropdown menu to executing a set of data?
  • How to make each option in a dropdown menu to executing a set of data?
    Posted by Hiro Ober on October 14, 2024 at 10:43 am
    I’m creating a 3D camera animation template with the goal of exporting it as a .mogrt for PR users. The controllable properties include animation duration, media replacement, media position adjustments, and the ability to choose from multiple pre-set camera angles. The path animation for each camera angle is pre-defined, and the user won’t have control over it. Since the duration is variable, it’s tricky to set keyframes directly, so the camera path animations are done through expressions. In short, each camera angle animation is achieved using XYZ rotation and position parameters. For example, the parameters for the first angle might be a 15° Y-axis rotation and 200 units of X-axis position movement. Ideally, I’d like these camera animations to be presented in a dropdown menu, with options like:
    1. Bottom to top
    2. Top to bottom
    3. Left to right
    4. Right to left
    I have created and linked all the properties on a null object, but how should I encapsulate a bunch of position and rotation data into different options? I mean manually writing expressions on each property is tedious and hard to tweak, right? Any better solutions?
    Yoan Boisjoli replied 1 year, 10 months ago 2 Members · 3 Replies
  • Yoan Boisjoli
    October 14, 2024 at 7:40 pm
    Hi Hiro! Something like this might work. I’m using ease() in this case but feel free to use easeOut(), easeIn() or linear() if you prefer.
    Position:
    var sel = effect(“Camera Angle”)(“Dropdown”);
    var duration = effect(“Animation Duration”)(“Slider”); // Assuming you have a duration slider
    // Define keyframes for each option
    var positions = [
    [[0, 0, 0], [200, 0, 0]], // Bottom to top
    [[0, 0, 0], [0, -200, 0]], // Top to bottom
    [[0, 0, 0], [-200, 0, 0]], // Left to right
    [[0, 0, 0], [200, 0, 0]] // Right to left
    // Calculate progress
    var t = time – inPoint;
    var progress = clamp(t / duration, 0, 1);
    // Interpolate using ease
    ease(progress, 0, 1, positions[sel-1][0], positions[sel-1][1]);
    And for Rotation:
    var rotations = [
    [[0, 0, 0], [0, 15, 0]], // Bottom to top
    [[0, 0, 0], [0, -15, 0]], // Top to bottom
    [[0, 0, 0], [0, 0, 15]], // Left to right
    [[0, 0, 0], [0, 0, -15]] // Right to left
    ease(progress, 0, 1, rotations[sel-1][0], rotations[sel-1][1]);
    I haven’t tested it but let me know if this is what you were looking for. 🙂
  • Hiro Ober
    October 16, 2024 at 11:51 am
    Appreciate it mate! I reckon I don’t entirely understand it yet, but I’ll def give it try!
  • Yoan Boisjoli
    October 31, 2024 at 12:12 pm
    Hey Hiro! I finaly got to test the expression and it wasn’t working so here’s a working one with the right steps:
    1. Make a null object and link you camera to it.
    2. add a dropdown menu and two sliders
    3. paste this expression in the position:
    // Retrieve the selected direction and duration
    var direction = effect("Direction")(1).value;
    var duration = effect("Duration")(1).value;
    var distance = effect("Distance")(1).value;
    // Define movement parameters
    var startPos = [0, 0]; // Starting position (relative to current position)
    var endPos;
    // Determine end position based on selected direction
    switch (direction) {
    case 1: // Bottom to Top
    endPos = [0, -distance];
    break;
    case 2: // Top to Bottom
    endPos = [0, distance];
    break;
    case 3: // Left to Right
    endPos = [distance, 0];
    break;
    case 4: // Right to Left
    endPos = [-distance, 0];
    break;
    default:
    endPos = [0, 0];
    // Determine current position using linear interpolation
    if (time < duration) {
    // Moving from startPos to endPos
    ease(time, 0, duration, startPos, endPos);
    } else {
    // After duration, stay at endPos
    endPos;
    Here’s a screenshot of how it looks for me.
