Activity Forums Zaxwerks How to make each letter to use its own set
  • How to make each letter to use its own set
    Posted by Dotan Baytman on November 21, 2006 at 9:48 am
    I searched the forum and tried to make each letter to have its own set but it didn”t work
    this is what i tried:
    I have this word “TEST”
    in the setup window i press the second letter and choose set 2 the third letter set 3 and so on
    but when i choose one of the letters its stay on the last set i”ve chosen for all the letters
    what am i missing here?
    thanx
    Jon Okerstrom replied 19 years, 9 months ago 2 Members · 4 Replies
  • Jon Okerstrom
    November 21, 2006 at 6:55 pm
    Hi dotan,
    Assign the letters different set number as you have, then close the set-up window.
    Now under the scene preview window, choose the set icon (three cubes). Now you should be able to select the sets containing individual letters.
    Does this help?
    Jon
  • Dotan Baytman
    November 22, 2006 at 10:55 am
    It still doesnt work
    ill explain again what im doing
    i have the text now i click on the second letter in the preview window and it turns red now i click the set 2 button and click the third letter that is now red and click set 3
    after i click outside the word and then see if it works all the letters are at the last set i have chosen
    is this the right way to choose the letters?
  • Dotan Baytman
    November 22, 2006 at 10:58 am
    I think i know whats the problem
    when i click on a letter it turns red but the rest are still green
    how can i click on just one letter?
    thanx
  • Jon Okerstrom
    November 23, 2006 at 1:16 am
    One way is to use the object pop-up menu below the set-up window. You can use it to choose one or more of your letters without actually clicking on them. You can also select invisible objects and deselect everything.
    Jon
