Activity Forums Adobe After Effects Expressions How to make curved motion using my existing expression?
  • How to make curved motion using my existing expression?
    Posted by Darryl Torke on February 28, 2014 at 3:10 am
    Hi, I have a very simple expression that uses the ‘easeIn’ expression, and it looks essentially like this:
    A=[0,500];
    B=[2000,500];
    easeIn(time,0,2,A,B);
    As you can see, the motion moves in a line from point A to point B, however it moves straight. I was wondering if there was a way to make the movement *curved*? (something like this: https://img.tfd.com/mgh/Investopedia/Yield_Curve.png is what I had in mind). And ideally, if there is anyway I could adjust this curve slightly if I have to.
    A=[0,500];
    B=[2000,500];
    Darby Edelen replied 12 years, 6 months ago 2 Members · 3 Replies
  • Darby Edelen
    February 28, 2014 at 5:14 am
    Is there some reason you can’t simply use keyframe animation?
    Darby Edelen
  • Darryl Torke
    February 28, 2014 at 7:32 pm
    Yes, sorry, the example is just a loose understanding. I use constantly changing variables, and each time I apply the layer the origin point and end point change (however the end point is always diagonal from the origin point). The full code is below:
    L = thisComp.layer("Origin");
    G1 = L.toWorld(L.anchorPoint,inPoint);
    G2 = L.toWorld(L.anchorPoint,inPoint) + [2000, 500];
    easeIn(time,inPoint,outPoint,G1,G2);
  • Darby Edelen
    February 28, 2014 at 9:50 pm
    Use another “template” layer’s motion path between 0 and 1 seconds to define the path the layer should follow.
    origin = effect("Origin")("Layer");
    template = effect("Motion Template")("Layer");
    start = origin.toWorld(origin.anchorPoint,inPoint);
    t = linear(time,inPoint,outPoint,0,1);
    a = template.toWorld(template.anchorPoint, 0);
    b = template.toWorld(template.anchorPoint, t);
    start + b - a;
    You’ll also notice that I’m pointing to a couple of Effect > Expression Control > Layer Controls on the layer instead of to the layers directly. This allows you to easily apply different Origin/Template layers to each layer.
    Darby Edelen
