Activity › Forums › Avid Media Composer › How to make creative transitions?
Posted by Lloyd Paul rivers on December 11, 2011 at 10:11 amHi all im new to editing and avid, been on final cut for around 2 years but have switched for university. I have a project where i want the transitions to be like “the plan” scene in sean of the dead.
heres a link to the scene im on about https://www.youtube.com/watch?v=VK17r6hN96k
Any hinters would be greatly appreciated
Lloyd
Steve Knattress replied 14 years, 9 months ago 7 Members · 9 Replies -
Job Ter burg
December 11, 2011 at 1:24 pmThose are zip pans (done in camera), probably with some soft wipes.
Lloyd Paul rivers
December 11, 2011 at 10:31 pmright thanks for that. Any productions tips? i did google it but there are no tutorials online shooting on 5dmk2
Many Thanks
Lloyd Rivers -
Shane Ross
December 12, 2011 at 2:31 amYou pan the camera really fast to the left and right. A WHIP pan. It’s fairly straight forward.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Bouke Vahl
December 12, 2011 at 4:10 pmThere is more to it.
In this movie (a MUST SEE BTW!) timing is crucial.
Without lots of takes / good direction it is hard to get the desired timing.
Jobs remark about a push / DVE makes this easier.
If you shoot (even a still image) left and right of the original framing, or a couple of stills, you can stitch a panorama, and do your DVE / push on the composit. (Don’t forget to add lots of motion blur, ae is good for this)Did i mention this movie is a must see?
Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Lloyd Paul rivers
December 12, 2011 at 5:13 pmThanks. i didn’t think something that looked this slick was as easy as a fast pan with the camera. totally agree with the must see too 🙂
Think ill spend the day testing it out
Many Thanks
Lloyd Rivers -
Neil Patience
December 12, 2011 at 9:00 pmOne thing to consider – if you are shooting with a 5D and whip pan that quickly – prepare for lots of shutter roll. Your left right pans will become “diagonal” looking which may look a little odd.
Some of the transitions are pushes with the image blurred as the push happens. Others are camera pans and tilts with a well timed cut between.
sometimes using a little motion blur as the move happens.
Most of the transitions seem to be over 6 frames – 3 each side of cut
It looks like on a couple of the transitions to the car they are including a few frames of a whip pan from another image betweeen the 2 shots.
Experiment with those kind of combinations and effects.
Its more in the timing and planning than anything really tricky effects-wise. Matching the speed of the incoming and outgoing movement is going to help it look smooth too.best wishes
Neil
http://www.patience.tv -
John Cuevas
December 13, 2011 at 3:50 pmIf you have access to AE, Carl Larsen has a tutorial that simulates whip pans. Depending on your Avid package(plugins) you might be able to do it Avid too.
https://library.creativecow.net/articles/larsen_carl/simulating_whip_pans.php
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”—THOMAS EDISON on inventing the light bulb.
Steve Knattress
December 14, 2011 at 12:11 pmalso if you have sapphire there is a swish-pan transition.
Also in Boris, but I find that needs more of a “tweak” to look as good.
Steve
