Activity › Forums › Apple Final Cut Pro Legacy › HOW TO MAKE AN INVISIBLE MAN ‘SEE-THROUGH’ in FCP
  • HOW TO MAKE AN INVISIBLE MAN ‘SEE-THROUGH’ in FCP
    Posted by Adam Coyle roach on March 14, 2009 at 7:34 pm
    Hello,
    Can anyone give me some advice…not sure where i should post this question.
    PLOT: I’m filming a talk show where the host is invisible.
    I’m shooting my subject in green screen suit against a green screen, and I want him to appear invisible, aside from anything he wears like a hat, etc (which works fine,)…but the environment he interacts with is affected by his hands when he places his hands on, say, a desk. What’s happening is that you can see straight through the desk and into the background I’ve chosen to layer behind (an ext. shot)
    Now it’s obvious why this is happening – my question is, how can i get around this? Am I looking at major Shake compositing of objects he interacts with or are there less complicated solutions?
    BASICALLY I WANT TO MAKE A PERSON COMPLETELY SEE THROUGH SO YOU CAN SEE OBJECTS THROUGH HIM, NOT JUST KEYED OUT (to another background…on a different video track.)
    I’m not seeing anything this in depth online so I hope someone sees this post and can help me out.
    thanks a bunch all, keep up the good work
    -Adam
    I don’t have a message signature, and I’m comfortable with that.
    Adam Coyle roach replied 17 years, 6 months ago 5 Members · 6 Replies
  • Michael Sacci
    March 14, 2009 at 10:22 pm
    [Adam Coyle Roach] “BASICALLY I WANT TO MAKE A PERSON COMPLETELY SEE THROUGH SO YOU CAN SEE OBJECTS THROUGH HIM, NOT JUST KEYED OUT (to another background…on a different video track.) “
    Using all caps is yelling, why are you yelling your question?
    You seem to be asking how do I make the actual person invisible.
  • Walter Biscardi
    March 14, 2009 at 10:30 pm
    YOU NEED TO START WITH A CLEAN SLATE SO YOU CAN THEN REPLACE ANYTHING THAT GETS KEYED OUT BY YOUR ACTOR.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Joshua Brown
    March 15, 2009 at 12:34 am
    You’re going to need a clean slate. Then you’ll most likely have to tween the movement of objects in the scene. My suggestion would be to shoot your slate. Then Simply shoot the objects you want the “invisible” man to interact with. Run a live preview of the objects being filmed overlaid on your slate to watch the interaction. Then film the man with his hat on or whatever. It’s going to be very complex to pull it off.
    A slightly alternative method is to shoot the “plate” and the object movement at the same time then rotoscope out the stick or wires you use to move them. Then film the man on green-screen later.
    It’ll be tricky. I’d love to see this if/when you are done.
    -Josh
  • Bill Davis
    March 15, 2009 at 12:44 am
    Unless I misunderstand you, you’re making this WAY too complicated.
    Say you want to do a 10 second “invisible man” walkon shot of him entering and sitting down at the desk.
    Just lock down the shot and shoot 15 seconds or so of a static shot of the set. Then have the man walk on and sit down at the desk.
    Put those TWO shots on different tracks and set the opacity of the second shot (the one with the guy) at between 40 and 60% depending on how “invisible you want him to be.
    If you want him to interact with the visible objects, eg answer the phone. THEN you need to deal with separate keying issues and generating moving mattes to isolate objects in one layer to interace with objects in other layers.
    But the basic invisible man stuff is about as simple as my first two paragraphs indicate.
    Good luck.
  • Adam Coyle roach
    March 15, 2009 at 3:34 am
    Re: Michael Sacci – I was not aware CAPS meant yelling, or at least I didn’t think it would offend anyone’s sensibilites. i was simply trying to make the summary of my query stand out.
  • Adam Coyle roach
    March 15, 2009 at 4:17 am
    thanks to Walter and the others,
    here’s a still from screentests so we’re all on the same page…
    So…am i to understand that I need to film floating items on wires or sticks, like ie. a headband (to be put on the invisbile mans head) and then with 100% accuracy, in Shake, make that floating item track with the actor?
    (((((just so I’m clear here’s an example above; i’d like the glasses on the actor’s head to be visible through his head, because they go over the back of his skull.)))))))
    I apologize for not explaining this more clearly but i’m not a pro with production/post jargon yet.
    Thanks again to all 4 of you who are trying to help thus far.
    -Adam
