Activity › Forums › Adobe After Effects › How to make an image appear out of multiple lines of text
  • John Cuevas
    October 6, 2014 at 3:23 pm
    If you have trapcode particular, you could set up each line/word of text as a custom particle, then set up a grid effect that you animate, then play backwards.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
