Activity › Forums › Adobe Premiere Pro › how to make an EDL in premiere pro 7
  • how to make an EDL in premiere pro 7
    Posted by Olaf Steel on May 5, 2008 at 10:57 am
    hi.
    i need to create an EDL with premiere pro 7. i only need it for a project in college, so it simply has to be printed out.
    how can i do this?
    thank you,
    olaf
    Jon Barrie replied 18 years, 4 months ago 2 Members · 1 Reply
  • Jon Barrie
    May 6, 2008 at 2:21 am
    An EDL is an Edit Decision List. It will take each video and audio clip that is used in tracks video 1 and audio tracks 1,2,3,4. The list shows which shot was used in which order at the in/out points of its own timecode for the clip and then it’s timecode position in the whole timeline. It can be done by selecting the timeline you want to export the EDL from either selecting the timeline(sequence) in the project bin or opening the sequence and having the panel highlighted. Then goto File>Export>EDL… not sure of the exact wording in version 7, but File>Export is where you’ll see the EDL export choice.
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
