Activity › Forums › Adobe After Effects › How to make an Arc using JSX in AE 2023? And have it rotate?
  • How to make an Arc using JSX in AE 2023? And have it rotate?
    Posted by Pragyan Yadav on January 16, 2023 at 12:17 am
    I need to make a loading animation type arc using JS script, how can I do that?
    I tried this method
    but it gives me error “Object is Invalid”
    app.project.close(CloseOptions.DO_NOT_SAVE_CHANGES);
    app.newProject();
    app.beginUndoGroup("Create Comp");
    var width = 1920;
    var height = 1080;
    var duration = 10;
    var frameRate = 25;
    var bg = [1, 0, 0];
    var arc = [0, 1, 0];
    var comp = app.project.items.addComp("Comp", width, height, 1, duration, frameRate);
    comp.openInViewer();
    var layer = comp.layers.addSolid(bg, "Background", width, height, 1);
    var shapeLayer = comp.layers.addShape();
    shapeLayer.selected = true;
    var shapeGroup = shapeLayer.property("ADBE Root Vectors Group").addProperty("ADBE Vector Group");
    var arc = shapeGroup.property("ADBE Vectors Group").addProperty("ADBE Vector Shape - Ellipse");
    arc.property("ADBE Vector Ellipse Size").setValue([100, 200]);
    var arcFill = shapeGroup.property("ADBE Vectors Group").addProperty("ADBE Vector Graphic - Fill");
    var mask = shapeLayer.property("ADBE Mask Parade").addProperty("ADBE Mask Atom");
    mask.property("ADBE Mask Shape").setValue(arc.property("ADBE Vector Shape"));
    var maskPath = mask.property("ADBE Mask Shape");
    var startAngle = 0;
    var endAngle = 90;
    maskPath.setValueAtTime(0, [width/2, height/2, startAngle]);
    maskPath.setValueAtTime(duration, [width/2, height/2, endAngle]);
    var rotation = shapeLayer.transform.rotation.property("ADBE Vector Rotation");
    rotation.expression = "time * 360";
    app.endUndoGroup();
    Pragyan Yadav replied 3 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
