How To Make An AE Template for Multiple Text Comps
Hi there, this is my first post here in the forums and just wanted to say thank you to the amazing knowledge that’s here. I’ve dropped in several times and leaned so much – thanks.
Q: I make apps and find myself making the same 3D text buttons over and over again in After Effects using the Element 3D plugin which is perfect. I would like to know if anyone knows or could point me towards a tutorial about how I can make one single comp that contains the font I’ve chosen and the Element variables and apply that to several other comps that have different text in each comp?
I find myself duplicating comp 1 and then changing the text from Game Over to Continue, this works okay, although it’s a bit slow, but the problem comes when I’ve done this for 15-20 different buttons and I want to change the bevel, colour, or font I find myself going into each comp to do each one and this obviously wastes a lot of time.
For Example:
Comp 1 consists of:
1 x Text layer = Game Over
1 x Element 3D layer (with text layer set in the custom layers)
1 x CameraComp 2 consists of:
1 x Text layer = Start
1 x CameraComp 3 – different text
Comp 4 – different text
and so on for several compsI could save loads of time per game and for future games production, If I could find a way to be able to change a master comp that all other comps refer to for the font and Element 3D parameters like bevel preset and materials etc, whilst having all the other comps with their respective texts intact.
Many thanks in advance for any assistance you can provide.
All the best
Phill
