Activity › Forums › Adobe After Effects › How to make a voice sound like it’s coming over the telephone in post using AE CS5 sound tools?
  • How to make a voice sound like it’s coming over the telephone in post using AE CS5 sound tools?
    Posted by Matt Crunk on October 10, 2012 at 8:59 pm
    I already have the actor’s voice recording with the video and had rather not have to do a an ADR session if I can avoid it. Also what settings could I use to take a little bit of room echo out of the voice? It’s not terrible as-is, but would be better if I could dry it up a bit.
    John Cuevas replied 13 years, 11 months ago 3 Members · 2 Replies
  • Clay Stearns
    October 10, 2012 at 10:30 pm
    I am by no means an expert and I don’t normally use After Effects for sound, but this might help you get started.
    For the phone effect you want to create an EQ filter so only 400-1k is coming out. Narrowing the bands even more will heighten the effect. Parametric EQ is the effect but I don’t know how it works in AE.
    For the room echo add the reverb effect and play with the wet/dry controls. You may have some success going to a negative reverb as well.
    Hope that helps,
    Clay
  • John Cuevas
    October 11, 2012 at 12:11 am
    As you probably have learned, AE really isn’t the program you want to use to create audio effects. If you don’t have Audition(which has a pre-built telephone eq), you could download Soundforge’s Audacity and then follow this tutorial for creating telephone-like audio.
    https://www.youtube.com/watch?v=G688bPA7nS4
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
