Activity › Forums › Apple Final Cut Pro › How to make a video loop in fcpx ????
Posted by Morten Søby on December 25, 2011 at 7:09 pmI need to make a video that loops but when i export the movie it plays and ends at last frame, does any of you have an idea to how i get it to loop automatically when its played on a external display/tv.
can it be done in fcpx or what program do i need to use.Chance Mcclain replied 12 years, 4 months ago 6 Members · 6 Replies -
Jeremy Garchow
December 25, 2011 at 7:43 pmYou either build in the loop and extend a long movie, or use the loop function of QuickTime if you’re using QuickTime to playback (you can also set a loop flag in QT). DVDs have loop functions as well.
What’s your playback method?
Bill Davis
December 26, 2011 at 5:58 amThere’s also a nice little app called LoopyLoopy that will set any QT video into endless loop mode from an iPhone or iPad. If you have an iOS device and it’s attendant doc connector to VGA adapter, that’s another approach.
If you want to run from a laptop – PlaybackPro from DTV labs has got a pretty stellar rep. But it’s not as cheap. And of course you’ll need the proper Apple dongle to get video out of your particular version of the mac video out VGA/DisplayPort connection.
Depends very much on the hardware and output capabilities you need.
“Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Mark Morache
December 26, 2011 at 5:17 pmBoth quicktime 7 and quicktime X have a loop function if you’re playing off of a mac. It’s under the View menu. Command L is the keyboard shortcut.
[Jeremy Garchow] “you can also set a loop flag in QT”
Jeremy, are you saying there’s a way to set a flag in the quicktime video to force it to loop?
FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
https://fcpx.wordpress.com -
Russ Andris
December 28, 2011 at 2:35 pmMorten Soby
Have you tried this.
Highlight the clip, click on the retiming tool icon, and try instant replay.
This has worked for me.
Russ
Chance Mcclain
May 12, 2014 at 4:49 pmThe Instant Replay worked great for me. I had a 30 sec loop I needed to run for 15 min and it was perfect.
