Activity Forums Adobe After Effects How to make a video like this….
  • How to make a video like this….
    Posted by Luis Garcia on September 18, 2015 at 9:17 am
    Hi! I am trying to do a video like this…
    https://www.youtube.com/watch?v=eMj4DMK0HSo
    It is a selfhelp video, and I would like to know doing it for myself. The most important thing I would like to know is how to do the text so quickly, in a random mode…. The images I know how get the effect.
    The text is a continuos flashing… I don´t know if perhaps with a script I could do it….
    some idea?
    Thanks in advance
    Luis Garcia replied 10 years, 8 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    September 19, 2015 at 6:59 am
    It looks more like a very fast scroll. You can do this with the Effect>Stylize>Motion Tile and the Expression –
    loopOut(“cycle”).
    You’ll need TWO keyframes for the Tile Center property. Leave the x value at its default. For the first keyframe’s y-value, set it to 0, for the second y-value, set it to the height of your composition. The two keyframes should be close together – about 4-7 frames apart.
    Then, apply the aforementioned Expression to the Tile Center prop. Of course, enable Motion Blur for the layer and Comp. Adjust Motion Blur settings to taste.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Luis Garcia
    September 21, 2015 at 8:40 am
    A lot of Thanks… I will try it!
