Activity Forums Adobe After Effects How to make a traditional cartoon texture effect in after effects?
  • How to make a traditional cartoon texture effect in after effects?
    Posted by James Mayo on June 19, 2013 at 5:04 am
    i’m doing an animation for my video project. Please help me 🙂
    How do you make this effect in after effects?
    https://www.vimeo.com/68137549
    thanks so much!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    James Mayo replied 13 years, 2 months ago 4 Members · 4 Replies
  • Joseph W. bourke
    June 19, 2013 at 3:08 pm
    While there are ways to get close to the look using a plugin such as Red Giant ToonIt:
    https://www.redgiant.com/products/all/toonit/
    …this appears to have been done by shooting or capturing the reference video, then rotoscoping with pencil and markers (or possibly in Photoshop with the appropriate brushes), frame by frame, then editing the project, adding VO and music. There’s no simple, one click solution – it’s a lot of work.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Todd Kopriva
    June 19, 2013 at 4:59 pm
    Joe is correct, and I’m not suggesting that the Cartoon effect is adequate by itself in all cases, but you can get a result that is similar (and maybe good enough for your current needs) using the Cartoon effect.
    After Effects team blog
  • Joey Trimmer
    June 19, 2013 at 5:14 pm
    It seems to me that these these are mostly hand drawn elements and animated using a looping turbulent displace effect so that the lines wiggle between frames.
    There is also a texture that looks like it loops on top of everything. Maybe a fractal noise could help with that or create these in photoshop and overlay them on top of your footage.
  • James Mayo
    June 20, 2013 at 1:46 am
    Hi Joseph!
    Thanks for your reply! 🙂
    Actually before i post my query here, i exported the video first in jpeg seq then edit each photo in photoshop. Now i have to do a lot of work! 🙂
    thanks so much guys!! 🙂
    It’s Time for the 2nd Coming
