Activity Forums Adobe After Effects How To Make A Static Image Look Horrific
  • How To Make A Static Image Look Horrific
    Posted by Michael Bayouth on July 16, 2006 at 6:19 pm
    How Do I Make A Static Image Look Horrific?
    My horror film features an inanimate, rotting, corpse in a cage. A scary voice over accompanies it.
    Unfortunately, at times, this corpse is not that horrific looking. That’s my problem.
    Is there something I can do digitally to spice it up – make it scarier? A rotting displacement map or something?
    I plan to do a slight push-in and maybe a slight rotation. Rotting SFX will be added as well. But I need something more.
    Keeping in mind, this corpse is mosly behind the grid of its cage.
    I’m open for any ideas.
    Thanks all!
    BayDog
    Michael Bayouth replied 20 years, 2 months ago 4 Members · 6 Replies
  • Lars Bunch
    July 16, 2006 at 8:17 pm
    Here’s my 2 cents…
    Don’t show much of it. What you can’t see can be a lot more frightening than what you can. When the mechanical shark looked too stupid to show in Jaws, it helped the film quite a lot.
    Add a glistening sheen to it. Ridley Scott knew the value of wet and slimy in “Alien” I imagine you could use a glass effect with some evolution to give an undulating quality to the wet look.
    Give it a sickly green cast. Perhaps even a bit of a glow. Unless it’s a tree, green doesn’t look too healthy.
    These are the obvious things that come to mind immediately. You can probably think of more original ones. Anyway, my feeling is things that seem subtly unnatural tend to be more creepy than big “gross out” effects.
    Hope this helps,
    Lars
  • Steve Roberts
    July 16, 2006 at 8:25 pm
    Bump up the saturation. More bright red in the red bits. Shiny. Wet. Sound of flies.
    Cut the shot in stepped zooms. Boom-boom-boom. Medium-CU-BCU.
  • Graham Quince
    July 17, 2006 at 7:52 am
    I’d also suggest a close up of blood dripping from a dead hand. maybe also a close up of the pool it makes. That way your one shot has become three, which gives the audience less time to see it’s fake.
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Michael Bayouth
    July 17, 2006 at 2:39 pm
    Thanks! Great idea!!
  • Michael Bayouth
    July 17, 2006 at 2:41 pm
    Really good advice. Thanks! I’ll do it. Is the glass effect done with a 3rd party filter?
    BayDog
  • Michael Bayouth
    July 17, 2006 at 2:42 pm
    Yes, good suggestion – Thanks a lot.
    BayDog
