Activity Forums Adobe After Effects How to make a selection ?
  • How to make a selection ?
    Posted by Bernhard Rieder on November 16, 2008 at 5:55 pm
    Hello,
    – I create a new green solid
    – I load a black-white alpha image (white circle, rest is black)
    Now I do have two layers, and on top the black-white alpha.
    How can I make a selection from just the white part ?
    If the selection is done, I just would like to make a copy of the green solid layer, paste and create a third layer with a different color.
    thx for every littel help
    Darby Edelen replied 17 years, 10 months ago 2 Members · 3 Replies
  • Darby Edelen
    November 17, 2008 at 12:14 am
    There are several ways to use the black and white image as an alpha for the solid.
    The most common are probably a Luma Track Matte or the Channel > Set Matte effect.
    Information on track mattes is available here:
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7cf9a.html
    Less common would be the Stencil Luma or Silhouette Luma blend modes, as these affect every layer below the stenciled/silhouetted layer.
    Darby Edelen
  • Bernhard Rieder
    November 17, 2008 at 2:19 am
    thank you for the info, I really appreciate that.
    it wasn’t really the answer I was looking for.
    I was looking for a simple selection solution.
    I’ve explored and know already how I can use the track mattes, but I wanted to do somethign much more easier.
    In Photoshop, you can simple select an Alpha Layer, or also a Channel and his saved Alpha inside.
    Simple Click the Layer, or the Channel while pressing down the ALT button. Done… you get a selection, so you can cut out things.
    This is my question – how can I make such a simple selection in AE ?
    thx for your help
  • Darby Edelen
    November 17, 2008 at 4:05 am
    [Bernhard Rieder] “This is my question – how can I make such a simple selection in AE ?”
    There is nothing in AE that works quite the same way as a selection in PS. However, a selection in PS can essentially be thought of as an alpha channel (as you noted in your previous post). So pretty much anything you can think of doing with a selection in PS can be done with some kind of a matte or masks in AE (which you use depends on your needs).
    It’s all a matter of thinking about things in a different way. If you tell me what you’re trying to accomplish with a selection, I’m sure I can provide you a solution in AE.
    Darby Edelen
