Activity Forums Maxon Cinema 4D How to make a perfectly right angled square sweep nurb?
  • How to make a perfectly right angled square sweep nurb?
    Posted by 00neil on January 18, 2007 at 11:15 am
    How do I get a perfectly right angled square sweep nurb? I have a spline with no curves that I want to be square, but whenever I apply the sweep nurb it ends up being flat or misshaped on one of the axis
    00neil replied 19 years, 7 months ago 3 Members · 3 Replies
  • Mikeh64
    January 18, 2007 at 4:01 pm
    it’s not entirely clear what you are trying to get and what the problem is, but one suggestion would be trying to adjust the axis orientation of the spline you are sweeping (turn the axis only, not the whole spline)
  • Designbytes
    January 19, 2007 at 12:44 am
    works here….
    1. create rectangular, square or whatever sweep spline
    2. create the square profile spline
    3. create the sweep nurb object
    4. drop #1 into the sweep nurb
    5. drop #2 into the sweep nurb
    if the resulting sweep nurb appears “flat” try adjusting the orientation of the profile nurb — XY, YZ, or XZ
  • 00neil Create COW Profile Image
    00neil
    January 20, 2007 at 11:31 am
    thanks designbytes, that worked.
