Activity Forums Adobe After Effects How to make a movie sequence PAL Interlaced?
  • How to make a movie sequence PAL Interlaced?
    Posted by Dario Cavallo on March 17, 2010 at 5:48 pm
    Io I have a movie PAL 720×576 interlaced 50th and I would turn it into progressive 25p.
    In-line in the Help aecs4 I read the page:
    http:/ / Help.Adobe.com / it_it/aftereffects/9.0/ws3878526689cb91655866c1103906c6dea-7f37a.html
    Title: "separate video fields":
    Note:
    To rapidly look more like a movie to your video editing, Import it twice, and interpret each footage item with an order of field
    Different. Then add both to the same composition and fondeteli together. Level interpreted incorrectly adds a blur-style film.
    1) What is meant to blend together?
    (…Then add both to the same composition and fondeteli together…) "
    2) I must use the command: "layer merge frames pixel Motion (moving pixels).”?
    3) rendering, I must then use the command: Render Settings rendering fields: "Disable", and even: Output module opzioniformato mpeg2-dvd
    Order field: "None (progressive)", To get the 25p progressive?
    4) this plugin: "frame rate converter" URL:
    https://www.Videocopilot.net / tutorials / frame_rate_converter / # leave_a_comment
    4a) can be useful to convert an interlaced movie in 25p progressive 50th?
    4b) or just use the settings of "separation of video fields and subsequent fusion, Aftereffectscs4 own in-line as mentioned in the Help?
    Thanks so much for an answer!
    Horsepower.
    Dario Cavallo replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
