Activity Forums Adobe After Effects How to make a line appear and disappear
  • How to make a line appear and disappear
    Posted by Dan Donaldson on September 10, 2011 at 9:38 pm
    Hello. I have a path that is shaped like a loop de loop. What I want to have is only an inch of the line visible as it traces the path. Now, how I am currently doing this is by using an Add Mask and manually positioning it around the path. I wanted to know if their is an easier way? Thank you
    Todd Kopriva replied 14 years, 12 months ago 3 Members · 2 Replies
  • Victor Nguyen
    September 11, 2011 at 12:23 am
    The stroke plugin is what you’re looking for. The stroke plugin uses a mask and it doesn’t have to be a close mask. after you draw out your mask, you can animate it. you can use one mask or you can use many mask, if you use many mask, you can make stroke reveal sequentially ( as in the first mask you make it will reveal, then it will reveal the second mask you make) A very good tool and perfect for your need. I hope you understand what I mean, if not I can go further into detail how to use it
  • Todd Kopriva
    September 11, 2011 at 3:09 am
    You can also use the Trim Paths path operator on a shape layer.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
