Activity › Forums › Adobe After Effects › how to make a dice only with lines (no fill) that doesn’t look transparent
  • how to make a dice only with lines (no fill) that doesn’t look transparent
    Posted by Marina Cotrim on January 12, 2016 at 4:20 pm
    Hello everyone,
    I would like to make a dice that has no fill, only lines. the problem is when a do that, it looks like the dice is transparent, but I don’t want to see the lines that are behind.
    I want to animate the dice and still be able to see just what’s in front, like it would be if the side had a fill color.
    Is it doable? Maybe there’s a script to help me?
    Thank you!!!
    Marina Cotrim replied 10 years, 8 months ago 4 Members · 4 Replies
  • Kevin Camp
    January 13, 2016 at 12:52 am
    would need to know more about how you have your dice constructed, but dan ebberts’ ‘layer invisible when facing away from camera’ expression might help.
    you’ll find it here (with a good description of how it works):
    https://motionscript.com/design-guide/invisible-facing-away.html
    it will only work if you are using 3d layers to create your dice ‘outlines’.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kalleheikki Kannisto
    January 13, 2016 at 9:44 am
    How about filling the sides with black or green and keying them out?
  • Tudor “ted” jelescu
    January 13, 2016 at 10:36 am
    You can try playing with find edges and see if that’s what you’re after
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Marina Cotrim
    January 15, 2016 at 3:04 pm
    Thank you!!!
    That is exactly what I needed!
