Activity Forums Adobe Premiere Pro how to make a cut at current playhead location
  • how to make a cut at current playhead location
    Posted by Josh Weiss on May 21, 2006 at 7:04 pm
    I know this is probably a very stupid question but, what is the shortcut to make a cut at the current playhead location without having to go into the razor tool. Also, where is the found in the keyboard customization menu?
    Acachia Schoniwitz replied 7 years, 8 months ago 10 Members · 10 Replies
  • 10 Replies
  • Craig Howard
    May 21, 2006 at 7:27 pm
    CTRL-K = Razor at CTI Position
    Note Keyboard shortcuts are listed in the menu under customisation.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Mbelli
    May 22, 2006 at 3:55 am
    Beware that CTRL-K cuts everything, not just your selected clip but all the clips underneath it. Wish it would just cut the clip selected.
  • Josh Weiss
    May 22, 2006 at 7:01 pm
    Does anyone know how to do this without cutting all tracks as mentioned in the previous post (and without using the razor tool)
  • Hector Melendez
    May 22, 2006 at 10:01 pm
    Control K if you never change in customization. To un-cut underneath tracks, the only way I have found is locking the tracks. (look at a lock icon at extreme left of the timeline.
    Remember you can custom-built the keyboard the better suit your workflow
    Mine is: Z to make cuts, X to riple delete,C page down, D default video transition, Control D default audio xsition With left hand I can control this commands while with right move the mouse. Fast way to me!
  • Victoria Ellis
    May 24, 2006 at 10:18 am
    If you wanted to cut a section out of the footage, instead of razoring in two places and then deleting the footage and closing the gap, put in and out points (using I and O keys) and then to ripple delete out press the ‘ key (middle row, second one in from the enter, but depending on keyboard customisation it might be the one directly next to the enter on the middle row).
    If you just want to lift the section out, do the in and out points and press the ; key (third one in from the enter on the middle row).
    If there are multiple layers, it will just do the edit to the selected video and audio tracks, and not the other tracks.
    Hope this helps.
    Victoria
  • David Goodwin
    March 18, 2013 at 1:33 pm
    Thanks, I had the same query so found this via Google.
  • Trig Simon
    March 4, 2016 at 5:49 pm
    I find the Shuttle Pro 2 as a handy tool. Makes shortcuts very simple. Your fingers do all the work without lifting your hand.
    Trig Simon
    Video Images by Trig
    832 Main
    Toledo OH 43605
    419-693-0872
    http://www.videoimagesbytrig.com
  • Werner Botha
    April 21, 2016 at 8:42 am
    To select which tracks will be cut using Ctrl+K activate track targeting for the selected tracks. To do this click on the track name next to the lock icon for the specific tracks you want to cut.
  • Yonatan Lehman
    August 15, 2016 at 11:24 am
    In version 2015.4 (maybe before – I don’t know)
    ctrl k cuts with no selected clip cuts all the enabled tracks
    ctrl k with an enabled clip cuts only the enabled clip
    ctrl shift K cuts all unlocked tracks – both enabled and disabled
  • Acachia Schoniwitz
    November 30, 2018 at 10:54 am
    Simply lock the layers you don’t want to be affected by the cut. It’s the lock icon, and locked layers will be grayed out with diagonal lines across them. ☺ Similar to Photoshop.
