Activity Forums Adobe After Effects How to make a clock like this?
  • David Franklin
    January 26, 2010 at 5:29 pm
    If it turns out that you DO know what Dave is referring to, then here’s a suggestion to go one step further:
    You could create a simple expression to fill the value of your number effect with the current time.
    Twirl down the “Numbers” effect, then twirl down the “Format” tab. Alt click on the stopwatch next to Value/Offset/Random Max and type the word “time” in the expression field that opens on the right.
    Then set the “Decimal Places” value to “2” and away you go!
    http://www.artisanaltelevision.com
    Made With Care In Brooklyn, NY
