Activity › Forums › Adobe After Effects › How to make a 3D rectangle to wrap a layer around?
Posted by Matthew Ruiz on August 12, 2015 at 9:27 amI am very curious as to how people make 3D rectangles that they then wrap layer or materials if you will around them in After Effects
Example: https://videohive.net/item/minimal-website-presentation-2/11805673
Paul Esteves replied 11 years, 1 month ago 3 Members · 4 Replies -
Kalleheikki Kannisto
August 12, 2015 at 12:59 pmPossibly like this.
You’ll need to load some 1920×1080 footage to replace the missing one.
I didn’t spend much time on it, so the edges don’t line up that good, but you get the idea.
Matthew Ruiz
August 12, 2015 at 3:15 pmThank you for the file! I unfortunately am unable to open it get version error problem is there anyway we could sort this out?
My current version is CS6
Thank you in advance,
Matt
August 13, 2015 at 7:50 amI can’t save back to CS6, so the next best thing is to explain it. Here’s a grab of the precomp:
If you look at the top view, I added guides where I wanted the footage to wrap, then duplicated the layer 4 times. I added a mask to each layer to create the top, bottom, left and right edges, moved the anchor points to the edge of the front face and rotated the edge slices 90 degrees on the x or y axis. Finally parented the edge to the front face.
I precomped it for tidiness, but that is not a required step. Remember to turn on collapse transformations if you precomp and want to use the camera in the main comp.
Paul Esteves
August 13, 2015 at 8:43 amYou could also use something like this: https://creativedojo.net/introducing-dojo-extruder-script/ or https://aescripts.com/3d-extruder/ I think? Basically just duplicates the layer and offsets it in z space a bunch of times till you get your desired thickness. Not sure if it’ll give you the exact results you want, but it could work.
