Activity Forums Adobe After Effects How to make a 3d Path connect 2 Cities on a Map
  • How to make a 3d Path connect 2 Cities on a Map
    Posted by Oskar Ziemba on November 6, 2010 at 2:38 pm
    Hello Forum,
    i have a map animation and everything is fine, except that i fail to do a 3D Arrow.
    Here is a layout of my animation:
    https://www.vimeo.com/16562374
    As you can see the 3D Path doesn’t move right at the start and thats what i want to remedy.
    My Comp is like this:
    i have the Map part in a precomp “A” and i put them in different positions in z-space. Now i added that precomp “A” to another Precomp “B” for the cameraflight and the light, where i use the z-space scale property to let the map-parts fly in. As you see that works fine.
    BUT if i put a 3D Shape layer in that composition “B” it doesn’t work… I get no shadow of the shape layer on the map and it is not 3D. So i made a 3rd composition in which i put my 3D Path to move from Point A to B. But then i have the Problem that i described above, because of the camera motion and zoom the arrow doesn’t move right or i would have a tremendous amount of fiddling before i get it right.
    My Question is: Why can’t i put the shape Layer in comp “B” because than i wouldn’t have to worry about the camera motion. What am i overlooking?
    I hope i described my problem well enough.
    i found this post, but it didn’t really help me: https://forums.creativecow.net/thread/2/960329#960418
    Oskar
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Oskar Ziemba replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
